Voici ce que j'ai avec la commande dmesg.
0, disabled.
[ 0.405001] ACPI: PCI Interrupt Link [LNK4] (IRQs *3 4 5 7 9 10 11 12 14 15)
[ 0.405155] ACPI: PCI Interrupt Link [LNK5] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.405312] ACPI: PCI Interrupt Link [LUBA] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.405467] ACPI: PCI Interrupt Link [LUBB] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.405620] ACPI: PCI Interrupt Link [LMAC] (IRQs *3 4 5 7 9 10 11 12 14 15)
[ 0.405772] ACPI: PCI Interrupt Link [LACI] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.405923] ACPI: PCI Interrupt Link [LMCI] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.406075] ACPI: PCI Interrupt Link [LSMB] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.406227] ACPI: PCI Interrupt Link [LUB2] (IRQs *3 4 5 7 9 10 11 12 14 15)
[ 0.406378] ACPI: PCI Interrupt Link [LIDE] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.406543] ACPI: PCI Interrupt Link [LSID] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.406704] ACPI: PCI Interrupt Link [LFID] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.406865] ACPI: PCI Interrupt Link [LPCA] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.407042] ACPI: PCI Interrupt Link [APC1] (IRQs 16) *0
[ 0.407213] ACPI: PCI Interrupt Link [APC2] (IRQs 17) *0
[ 0.407383] ACPI: PCI Interrupt Link [APC3] (IRQs 18) *0, disabled.
[ 0.407554] ACPI: PCI Interrupt Link [APC4] (IRQs 19) *0
[ 0.407660] ACPI: PCI Interrupt Link [APC5] (IRQs *16), disabled.
[ 0.407842] ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22 23) *0
[ 0.408025] ACPI: PCI Interrupt Link [APCG] (IRQs 20 21 22 23) *0, disabled.
[ 0.408205] ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22 23) *0
[ 0.408387] ACPI: PCI Interrupt Link [APCJ] (IRQs 20 21 22 23) *0
[ 0.408577] ACPI: PCI Interrupt Link [APCK] (IRQs 20 21 22 23) *0, disabled.
[ 0.408761] ACPI: PCI Interrupt Link [APCS] (IRQs 20 21 22 23) *0
[ 0.408946] ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22 23) *0
[ 0.409127] ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22 23) *0, disabled.
[ 0.409316] ACPI: PCI Interrupt Link [APSI] (IRQs 20 21 22 23) *0
[ 0.409510] ACPI: PCI Interrupt Link [APSJ] (IRQs 20 21 22 23) *0
[ 0.409705] ACPI: PCI Interrupt Link [APCP] (IRQs 20 21 22 23) *0, disabled.
[ 0.409846] vgaarb: device added: PCI:0000:02:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.409848] vgaarb: loaded
[ 0.410008] SCSI subsystem initialized
[ 0.410143] libata version 3.00 loaded.
[ 0.410227] usbcore: registered new interface driver usbfs
[ 0.410240] usbcore: registered new interface driver hub
[ 0.410270] usbcore: registered new device driver usb
[ 0.410435] ACPI: WMI: Mapper loaded
[ 0.410437] PCI: Using ACPI for IRQ routing
[ 0.410613] NetLabel: Initializing
[ 0.410614] NetLabel: domain hash size = 128
[ 0.410616] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.410632] NetLabel: unlabeled traffic allowed by default
[ 0.412698] AppArmor: AppArmor Filesystem Enabled
[ 0.412722] pnp: PnP ACPI init
[ 0.412749] ACPI: bus type pnp registered
[ 0.418553] pnp: PnP ACPI: found 16 devices
[ 0.418555] ACPI: ACPI bus type pnp unregistered
[ 0.418575] system 00:01: ioport range 0x4000-0x407f has been reserved
[ 0.418579] system 00:01: ioport range 0x4080-0x40ff has been reserved
[ 0.418582] system 00:01: ioport range 0x4400-0x447f has been reserved
[ 0.418585] system 00:01: ioport range 0x4480-0x44ff has been reserved
[ 0.418587] system 00:01: ioport range 0x4800-0x487f has been reserved
[ 0.418590] system 00:01: ioport range 0x4880-0x48ff has been reserved
[ 0.418597] system 00:02: ioport range 0x4d0-0x4d1 has been reserved
[ 0.418600] system 00:02: ioport range 0x800-0x87f has been reserved
[ 0.418603] system 00:02: ioport range 0x290-0x297 has been reserved
[ 0.418612] system 00:0e: iomem range 0xe0000000-0xefffffff has been reserved
[ 0.418618] system 00:0f: iomem range 0xf0000-0xf3fff could not be reserved
[ 0.418621] system 00:0f: iomem range 0xf4000-0xf7fff could not be reserved
[ 0.418625] system 00:0f: iomem range 0xf8000-0xfbfff could not be reserved
[ 0.418628] system 00:0f: iomem range 0xfc000-0xfffff could not be reserved
[ 0.418631] system 00:0f: iomem range 0x7fff0000-0x7fffffff could not be reserved
[ 0.418634] system 00:0f: iomem range 0xffff0000-0xffffffff has been reserved
[ 0.418637] system 00:0f: iomem range 0x0-0x9ffff could not be reserved
[ 0.418640] system 00:0f: iomem range 0x100000-0x7ffeffff could not be reserved
[ 0.418643] system 00:0f: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 0.418647] system 00:0f: iomem range 0xfee00000-0xfeefffff has been reserved
[ 0.418650] system 00:0f: iomem range 0xfefff000-0xfeffffff has been reserved
[ 0.418653] system 00:0f: iomem range 0xfff80000-0xfff80fff has been reserved
[ 0.418656] system 00:0f: iomem range 0xfff90000-0xfffbffff has been reserved
[ 0.418659] system 00:0f: iomem range 0xfffed000-0xfffeffff has been reserved
[ 0.423385] Switching to clocksource acpi_pm
[ 0.423758] pci 0000:00:09.0: PCI bridge, secondary bus 0000:05
[ 0.423758] pci 0000:00:09.0: IO window: 0x9000-0xafff
[ 0.423758] pci 0000:00:09.0: MEM window: 0xd3000000-0xd4ffffff
[ 0.423758] pci 0000:00:09.0: PREFETCH window: 0x80000000-0x800fffff
[ 0.423758] pci 0000:00:0b.0: PCI bridge, secondary bus 0000:04
[ 0.423758] pci 0000:00:0b.0: IO window: disabled
[ 0.423758] pci 0000:00:0b.0: MEM window: disabled
[ 0.423758] pci 0000:00:0b.0: PREFETCH window: disabled
[ 0.423758] pci 0000:00:0c.0: PCI bridge, secondary bus 0000:03
[ 0.423758] pci 0000:00:0c.0: IO window: disabled
[ 0.423758] pci 0000:00:0c.0: MEM window: disabled
[ 0.423758] pci 0000:00:0c.0: PREFETCH window: disabled
[ 0.423758] pci 0000:00:0d.0: PCI bridge, secondary bus 0000:02
[ 0.423758] pci 0000:00:0d.0: IO window: disabled
[ 0.423758] pci 0000:00:0d.0: MEM window: 0xd0000000-0xd2ffffff
[ 0.423758] pci 0000:00:0d.0: PREFETCH window: 0x000000c0000000-0x000000cfffffff
[ 0.423758] pci 0000:00:0e.0: PCI bridge, secondary bus 0000:01
[ 0.423758] pci 0000:00:0e.0: IO window: disabled
[ 0.423758] pci 0000:00:0e.0: MEM window: disabled
[ 0.423758] pci 0000:00:0e.0: PREFETCH window: disabled
[ 0.423758] pci 0000:00:09.0: setting latency timer to 64
[ 0.423758] pci 0000:00:0b.0: setting latency timer to 64
[ 0.423758] pci 0000:00:0c.0: setting latency timer to 64
[ 0.423758] pci 0000:00:0d.0: setting latency timer to 64
[ 0.423758] pci 0000:00:0e.0: setting latency timer to 64
[ 0.423758] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.423758] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffffffffffff]
[ 0.423758] pci_bus 0000:05: resource 0 io: [0x9000-0xafff]
[ 0.423758] pci_bus 0000:05: resource 1 mem: [0xd3000000-0xd4ffffff]
[ 0.423758] pci_bus 0000:05: resource 2 pref mem [0x80000000-0x800fffff]
[ 0.423758] pci_bus 0000:05: resource 3 io: [0x00-0xffff]
[ 0.423758] pci_bus 0000:05: resource 4 mem: [0x000000-0xffffffffffffffff]
[ 0.423758] pci_bus 0000:02: resource 1 mem: [0xd0000000-0xd2ffffff]
[ 0.423758] pci_bus 0000:02: resource 2 pref mem [0xc0000000-0xcfffffff]
[ 0.423758] NET: Registered protocol family 2
[ 0.423758] IP route cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.423758] TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
[ 0.424718] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.425515] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.425520] TCP reno registered
[ 0.425652] NET: Registered protocol family 1
[ 0.440102] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.440108] pci 0000:00:0b.0: Found disabled HT MSI Mapping
[ 0.440116] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.440119] pci 0000:00:0b.0: Linking AER extended capability
[ 0.440158] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.440164] pci 0000:00:0c.0: Found disabled HT MSI Mapping
[ 0.440171] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.440174] pci 0000:00:0c.0: Linking AER extended capability
[ 0.440217] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.440222] pci 0000:00:0d.0: Found disabled HT MSI Mapping
[ 0.440229] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.440232] pci 0000:00:0d.0: Linking AER extended capability
[ 0.440279] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.440284] pci 0000:00:0e.0: Found disabled HT MSI Mapping
[ 0.440292] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.440294] pci 0000:00:0e.0: Linking AER extended capability
[ 0.440321] pci 0000:02:00.0: Boot video device
[ 0.441522] Scanning for low memory corruption every 60 seconds
[ 0.441670] audit: initializing netlink socket (disabled)
[ 0.441686] type=2000 audit(1290443108.440:1): initialized
[ 0.451259] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.452958] VFS: Disk quotas dquot_6.5.2
[ 0.453024] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.453788] fuse init (API version 7.13)
[ 0.453880] msgmni has been set to 4001
[ 0.454163] alg: No test for stdrng (krng)
[ 0.454231] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.454234] io scheduler noop registered
[ 0.454236] io scheduler anticipatory registered
[ 0.454238] io scheduler deadline registered
[ 0.454292] io scheduler cfq registered (default)
[ 0.454475] alloc irq_desc for 24 on node 0
[ 0.454477] alloc kstat_irqs on node 0
[ 0.454487] pcieport 0000:00:0b.0: irq 24 for MSI/MSI-X
[ 0.454493] pcieport 0000:00:0b.0: setting latency timer to 64
[ 0.454594] alloc irq_desc for 25 on node 0
[ 0.454596] alloc kstat_irqs on node 0
[ 0.454601] pcieport 0000:00:0c.0: irq 25 for MSI/MSI-X
[ 0.454605] pcieport 0000:00:0c.0: setting latency timer to 64
[ 0.454704] alloc irq_desc for 26 on node 0
[ 0.454706] alloc kstat_irqs on node 0
[ 0.454712] pcieport 0000:00:0d.0: irq 26 for MSI/MSI-X
[ 0.454716] pcieport 0000:00:0d.0: setting latency timer to 64
[ 0.454808] alloc irq_desc for 27 on node 0
[ 0.454810] alloc kstat_irqs on node 0
[ 0.454815] pcieport 0000:00:0e.0: irq 27 for MSI/MSI-X
[ 0.454820] pcieport 0000:00:0e.0: setting latency timer to 64
[ 0.454886] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.454919] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.455043] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.455047] ACPI: Power Button [PWRB]
[ 0.455113] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.455116] ACPI: Power Button [PWRF]
[ 0.455172] fan PNP0C0B:00: registered as cooling_device0
[ 0.455178] ACPI: Fan [FAN] (on)
[ 0.455770] processor LNXCPU:00: registered as cooling_device1
[ 0.455814] processor LNXCPU:01: registered as cooling_device2
[ 0.460803] thermal LNXTHERM:01: registered as thermal_zone0
[ 0.460811] ACPI: Thermal Zone [THRM] (40 C)
[ 0.462340] Linux agpgart interface v0.103
[ 0.462383] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.462479] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.462782] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.463942] brd: module loaded
[ 0.464448] loop: module loaded
[ 0.464549] input: Macintosh mouse button emulation as /devices/virtual/input/input2
[ 0.464869] pata_acpi 0000:00:06.0: setting latency timer to 64
[ 0.465375] ACPI: PCI Interrupt Link [APSI] enabled at IRQ 23
[ 0.465380] alloc irq_desc for 23 on node 0
[ 0.465383] alloc kstat_irqs on node 0
[ 0.465393] pata_acpi 0000:00:07.0: PCI INT A -> Link[APSI] -> GSI 23 (level, low) -> IRQ 23
[ 0.465417] pata_acpi 0000:00:07.0: setting latency timer to 64
[ 0.465424] pata_acpi 0000:00:07.0: PCI INT A disabled
[ 0.465807] ACPI: PCI Interrupt Link [APSJ] enabled at IRQ 22
[ 0.465810] alloc irq_desc for 22 on node 0
[ 0.465812] alloc kstat_irqs on node 0
[ 0.465817] pata_acpi 0000:00:08.0: PCI INT A -> Link[APSJ] -> GSI 22 (level, low) -> IRQ 22
[ 0.465846] pata_acpi 0000:00:08.0: setting latency timer to 64
[ 0.465853] pata_acpi 0000:00:08.0: PCI INT A disabled
[ 0.466292] Fixed MDIO Bus: probed
[ 0.466333] PPP generic driver version 2.4.2
[ 0.466388] tun: Universal TUN/TAP device driver, 1.6
[ 0.466390] tun: (C) 1999-2004 Max Krasnyansky
[ 0.466495] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.466850] ACPI: PCI Interrupt Link [APCL] enabled at IRQ 21
[ 0.466854] alloc irq_desc for 21 on node 0
[ 0.466856] alloc kstat_irqs on node 0
[ 0.466864] ehci_hcd 0000:00:02.1: PCI INT B -> Link[APCL] -> GSI 21 (level, low) -> IRQ 21
[ 0.466882] ehci_hcd 0000:00:02.1: setting latency timer to 64
[ 0.466885] ehci_hcd 0000:00:02.1: EHCI Host Controller
[ 0.466926] ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 1
[ 0.466954] ehci_hcd 0000:00:02.1: debug port 1
[ 0.466960] ehci_hcd 0000:00:02.1: cache line size of 64 is not supported
[ 0.466988] ehci_hcd 0000:00:02.1: irq 21, io mem 0xfeb00000
[ 0.480080] ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00
[ 0.480180] usb usb1: configuration #1 chosen from 1 choice
[ 0.480217] hub 1-0:1.0: USB hub found
[ 0.480226] hub 1-0:1.0: 10 ports detected
[ 0.480319] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.480678] ACPI: PCI Interrupt Link [APCF] enabled at IRQ 20
[ 0.480682] alloc irq_desc for 20 on node 0
[ 0.480684] alloc kstat_irqs on node 0
[ 0.480691] ohci_hcd 0000:00:02.0: PCI INT A -> Link[APCF] -> GSI 20 (level, low) -> IRQ 20
[ 0.480708] ohci_hcd 0000:00:02.0: setting latency timer to 64
[ 0.480711] ohci_hcd 0000:00:02.0: OHCI Host Controller
[ 0.480765] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 2
[ 0.480791] ohci_hcd 0000:00:02.0: irq 20, io mem 0xd5004000
[ 0.509671] Freeing initrd memory: 8140k freed
[ 0.542110] usb usb2: configuration #1 chosen from 1 choice
[ 0.542144] hub 2-0:1.0: USB hub found
[ 0.542153] hub 2-0:1.0: 10 ports detected
[ 0.542224] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.542322] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.545668] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.545675] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.545813] mice: PS/2 mouse device common for all mice
[ 0.545938] rtc_cmos 00:04: RTC can wake from S4
[ 0.545990] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 0.546012] rtc0: alarms up to one year, y3k, 242 bytes nvram
[ 0.546162] device-mapper: uevent: version 1.0.3
[ 0.546315] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised:
dm-devel@redhat.com
[ 0.546430] device-mapper: multipath: version 1.1.0 loaded
[ 0.546434] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.546678] cpuidle: using governor ladder
[ 0.546680] cpuidle: using governor menu
[ 0.547104] TCP cubic registered
[ 0.547268] NET: Registered protocol family 10
[ 0.547791] lo: Disabled Privacy Extensions
[ 0.548113] NET: Registered protocol family 17
[ 0.548162] powernow-k8: Found 1 AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ processors (2 cpu cores) (version 2.20.00)
[ 0.548174] [Firmware Bug]: powernow-k8: No compatible ACPI _PSS objects found.
[ 0.548176] [Firmware Bug]: powernow-k8: Try again with latest BIOS.
[ 0.548292] PM: Resume from disk failed.
[ 0.548306] registered taskstats version 1
[ 0.548611] Magic number: 2:755:439
[ 0.548713] rtc_cmos 00:04: setting system clock to 2010-11-22 16:25:09 UTC (1290443109)
[ 0.548717] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.548719] EDD information not available.
[ 0.548786] Freeing unused kernel memory: 872k freed
[ 0.549297] Write protecting the kernel read-only data: 7692k
[ 0.561938] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.571177] udev: starting version 151
[ 0.693544] Floppy drive(s): fd0 is 1.44M
[ 0.713427] sata_sil 0000:05:0a.0: version 2.4
[ 0.714213] FDC 0 is a post-1991 82077
[ 0.714589] ACPI: PCI Interrupt Link [APC4] enabled at IRQ 19
[ 0.714598] alloc irq_desc for 19 on node 0
[ 0.714600] alloc kstat_irqs on node 0
[ 0.714611] sata_sil 0000:05:0a.0: PCI INT A -> Link[APC4] -> GSI 19 (level, low) -> IRQ 19
[ 0.714649] sata_sil 0000:05:0a.0: Applying R_ERR on DMA activate FIS errata fix
[ 0.715156] pata_amd 0000:00:06.0: version 0.4.1
[ 0.715206] pata_amd 0000:00:06.0: setting latency timer to 64
[ 0.721054] scsi1 : pata_amd
[ 0.721338] scsi0 : sata_sil
[ 0.724515] scsi2 : pata_amd
[ 0.725317] ata5: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf000 irq 14
[ 0.725320] ata6: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xf008 irq 15
[ 0.725458] scsi3 : sata_sil
[ 0.725549] sata_nv 0000:00:07.0: version 3.5
[ 0.725563] sata_nv 0000:00:07.0: PCI INT A -> Link[APSI] -> GSI 23 (level, low) -> IRQ 23
[ 0.725622] sata_nv 0000:00:07.0: setting latency timer to 64
[ 0.725684] scsi4 : sata_sil
[ 0.725749] scsi5 : sata_nv
[ 0.725813] scsi6 : sata_sil
[ 0.725855] ata1: SATA max UDMA/100 mmio m1024@0xd4008000 tf 0xd4008080 irq 19
[ 0.725858] ata2: SATA max UDMA/100 mmio m1024@0xd4008000 tf 0xd40080c0 irq 19
[ 0.725862] ata3: SATA max UDMA/100 mmio m1024@0xd4008000 tf 0xd4008280 irq 19
[ 0.725865] ata4: SATA max UDMA/100 mmio m1024@0xd4008000 tf 0xd40082c0 irq 19
[ 0.725915] scsi7 : sata_nv
[ 0.726094] ata7: SATA max UDMA/133 cmd 0x9f0 ctl 0xbf0 bmdma 0xd800 irq 23
[ 0.726097] ata8: SATA max UDMA/133 cmd 0x970 ctl 0xb70 bmdma 0xd808 irq 23
[ 0.726150] sata_nv 0000:00:08.0: PCI INT A -> Link[APSJ] -> GSI 22 (level, low) -> IRQ 22
[ 0.726192] sata_nv 0000:00:08.0: setting latency timer to 64
[ 0.726240] scsi8 : sata_nv
[ 0.726309] scsi9 : sata_nv
[ 0.726492] ata9: SATA max UDMA/133 cmd 0x9e0 ctl 0xbe0 bmdma 0xc400 irq 22
[ 0.726495] ata10: SATA max UDMA/133 cmd 0x960 ctl 0xb60 bmdma 0xc408 irq 22
[ 0.730383] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.64.
[ 0.730835] ACPI: PCI Interrupt Link [APC2] enabled at IRQ 17
[ 0.730840] alloc irq_desc for 17 on node 0
[ 0.730842] alloc kstat_irqs on node 0
[ 0.730853] skge 0000:05:0c.0: PCI INT A -> Link[APC2] -> GSI 17 (level, low) -> IRQ 17
[ 0.730898] skge 1.13 addr 0xd4004000 irq 17 chip Yukon-Lite rev 9
[ 0.731629] skge eth0: addr 00:15:f2:55:5b:ab
[ 0.731948] ACPI: PCI Interrupt Link [APCH] enabled at IRQ 23
[ 0.731952] forcedeth 0000:00:0a.0: PCI INT A -> Link[APCH] -> GSI 23 (level, low) -> IRQ 23
[ 0.731956] forcedeth 0000:00:0a.0: setting latency timer to 64
[ 0.732003] nv_probe: set workaround bit for reversed mac addr
[ 1.050025] ata7: SATA link down (SStatus 0 SControl 300)
[ 1.070026] ata1: SATA link down (SStatus 0 SControl 310)
[ 1.210030] ata9: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.230233] ata9.00: ATA-7: MAXTOR STM3250310AS, 3.AAF, max UDMA/133
[ 1.230236] ata9.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 0/32)
[ 1.260891] forcedeth 0000:00:0a.0: ifname eth1, PHY OUI 0x5043 @ 9, addr 00:15:f2:55:34:46
[ 1.260895] forcedeth 0000:00:0a.0: highdma csum gbit lnktim desc-v3
[ 1.270235] ata9.00: configured for UDMA/133
[ 1.420030] ata2: SATA link down (SStatus 0 SControl 310)
[ 1.770028] ata3: SATA link down (SStatus 0 SControl 310)
[ 2.120023] ata4: SATA link down (SStatus 0 SControl 310)
[ 2.450017] ata8: SATA link down (SStatus 0 SControl 300)
[ 2.450171] scsi 8:0:0:0: Direct-Access ATA MAXTOR STM325031 3.AA PQ: 0 ANSI: 5
[ 2.450374] sd 8:0:0:0: Attached scsi generic sg0 type 0
[ 2.450382] sd 8:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 2.450504] sd 8:0:0:0: [sda] Write Protect is off
[ 2.450507] sd 8:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.450534] sd 8:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.450712] sda: sda1 sda2
[ 2.489209] sd 8:0:0:0: [sda] Attached SCSI disk
[ 2.780024] ata10: SATA link down (SStatus 0 SControl 300)
[ 2.784159] ACPI: PCI Interrupt Link [APC1] enabled at IRQ 16
[ 2.784166] alloc irq_desc for 16 on node 0
[ 2.784169] alloc kstat_irqs on node 0
[ 2.784180] ohci1394 0000:05:0b.0: PCI INT A -> Link[APC1] -> GSI 16 (level, low) -> IRQ 16
[ 2.850062] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[16] MMIO=[d4009000-d40097ff] Max Packet=[2048] IR/IT contexts=[4/8]
[ 3.109437] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 4.160167] ieee1394: Host added: ID:BUS[0-00:1023] GUID[0011d800007b6036]
[ 12.908507] udev: starting version 151
[ 12.998041] Adding 6028280k swap on /dev/sda5. Priority:-1 extents:1 across:6028280k
[ 13.015341] i2c i2c-0: nForce2 SMBus adapter at 0x4c00
[ 13.015368] i2c i2c-1: nForce2 SMBus adapter at 0x4c40
[ 13.022581] lp: driver loaded but no devices found
[ 13.195894] type=1505 audit(1290443122.143:2): operation="profile_load" pid=664 name="/sbin/dhclient3"
[ 13.196179] type=1505 audit(1290443122.143:3): operation="profile_load" pid=664 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 13.196339] type=1505 audit(1290443122.143:4): operation="profile_load" pid=664 name="/usr/lib/connman/scripts/dhclient-script"
[ 13.241334] EDAC MC: Ver: 2.1.0 Oct 16 2010
[ 13.253921] [drm] Initialized drm 1.1.0 20060810
[ 13.284738] parport_pc 00:09: reported by Plug and Play ACPI
[ 13.284790] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[ 13.290861] EDAC amd64_edac: Ver: 3.2.0 Oct 16 2010
[ 13.294419] EDAC amd64: This node reports that Memory ECC is currently disabled, set F3x44[22] (0000:00:18.3).
[ 13.294435] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[ 13.294437] Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
[ 13.294438] (Note that use of the override may cause unknown side effects.)
[ 13.294467] amd64_edac: probe of 0000:00:18.2 failed with error -22
[ 13.325906] nouveau 0000:02:00.0: PCI INT A -> Link[APC4] -> GSI 19 (level, low) -> IRQ 19
[ 13.325913] nouveau 0000:02:00.0: setting latency timer to 64
[ 13.333138] ppdev: user-space parallel port driver
[ 13.333432] [drm] nouveau 0000:02:00.0: Detected an NV40 generation card (0x042000a1)
[ 13.333760] [drm] nouveau 0000:02:00.0: Attempting to load BIOS image from PROM
[ 13.333775] [drm] nouveau 0000:02:00.0: ... BIOS signature not found
[ 13.333777] [drm] nouveau 0000:02:00.0: Attempting to load BIOS image from PRAMIN
[ 13.383877] [drm] nouveau 0000:02:00.0: ... appears to be valid
[ 13.383882] [drm] nouveau 0000:02:00.0: BIT BIOS found
[ 13.383885] [drm] nouveau 0000:02:00.0: Bios version 05.41.02.49
[ 13.383888] [drm] nouveau 0000:02:00.0: BIT table 'd' not found
[ 13.383891] [drm] nouveau 0000:02:00.0: Found Display Configuration Block version 3.0
[ 13.383895] [drm] nouveau 0000:02:00.0: DCB connector table: VHER 0x30 5 7 2
[ 13.383899] [drm] nouveau 0000:02:00.0: 0: 0x00001030: type 0x30 idx 0 tag 0x07
[ 13.383902] [drm] nouveau 0000:02:00.0: 1: 0x00000100: type 0x00 idx 1 tag 0xff
[ 13.383905] [drm] nouveau 0000:02:00.0: 2: 0x00000210: type 0x10 idx 2 tag 0xff
[ 13.383908] [drm] nouveau 0000:02:00.0: 3: 0x00000211: type 0x11 idx 2 tag 0xff
[ 13.383911] [drm] nouveau 0000:02:00.0: 4: 0x00000213: type 0x13 idx 2 tag 0xff
[ 13.383914] [drm] nouveau 0000:02:00.0: Raw DCB entry 0: 01000300 00000028
[ 13.383917] [drm] nouveau 0000:02:00.0: Raw DCB entry 1: 01000302 00000000
[ 13.383920] [drm] nouveau 0000:02:00.0: Raw DCB entry 2: 04011310 00000028
[ 13.383923] [drm] nouveau 0000:02:00.0: Raw DCB entry 3: 020223f1 0040c083
[ 13.383930] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 0 at offset 0xDDF7
[ 13.384231] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 1 at offset 0xE2C4
[ 13.384495] lp0: using parport0 (interrupt-driven).
[ 13.432361] gameport: NS558 PnP Gameport is pnp00:0d/gameport0, io 0x201, speed 898kHz
[ 13.473829] logips2pp: Detected unknown logitech mouse model 115
[ 13.570234] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 2 at offset 0xE7A3
[ 13.570256] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 3 at offset 0xE91A
[ 13.630026] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 4 at offset 0xE9EE
[ 13.635621] [TTM] Zone kernel: Available graphics memory: 1029000 kiB.
[ 13.635638] [drm] nouveau 0000:02:00.0: 256 MiB VRAM
[ 13.636480] [drm] nouveau 0000:02:00.0: 64 MiB GART (aperture)
[ 13.636941] [drm] nouveau 0000:02:00.0: Allocating FIFO number 0
[ 13.637834] [drm] nouveau 0000:02:00.0: nouveau_channel_alloc: initialised FIFO 0
[ 13.637842] [drm] nouveau 0000:02:00.0: Initial CRTC_OWNER is 0
[ 13.637848] [drm] nouveau 0000:02:00.0: Saving VGA fonts
[ 13.689222] [drm] nouveau 0000:02:00.0: Detected a DVI-I connector
[ 13.689561] [drm] nouveau 0000:02:00.0: Detected a VGA connector
[ 13.689750] [drm] nouveau 0000:02:00.0: Detected a TV connector
[ 13.691027] [drm] nouveau 0000:02:00.0: Setting dpms mode 3 on vga encoder (output 0)
[ 13.691031] [drm] nouveau 0000:02:00.0: Setting dpms mode 3 on tmds encoder (output 1)
[ 13.691035] [drm] nouveau 0000:02:00.0: Setting dpms mode 3 on vga encoder (output 2)
[ 13.691038] [drm] nouveau 0000:02:00.0: Setting dpms mode 3 on TV encoder (output 3)
[ 13.825911] ACPI: PCI Interrupt Link [APCJ] enabled at IRQ 22
[ 13.825920] Intel ICH 0000:00:04.0: PCI INT A -> Link[APCJ] -> GSI 22 (level, low) -> IRQ 22
[ 13.825960] Intel ICH 0000:00:04.0: setting latency timer to 64
[ 13.837772] skge eth0: enabling interface
[ 13.841404] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.860614] eth1: no link during initialization.
[ 13.862128] ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 13.874192] type=1505 audit(1290443122.821:5): operation="profile_load" pid=871 name="/usr/share/gdm/guest-session/Xsession"
[ 13.876136] type=1505 audit(1290443122.821:6): operation="profile_replace" pid=872 name="/sbin/dhclient3"
[ 13.876432] type=1505 audit(1290443122.821:7): operation="profile_replace" pid=872 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 13.876600] type=1505 audit(1290443122.821:8): operation="profile_replace" pid=872 name="/usr/lib/connman/scripts/dhclient-script"
[ 13.880822] type=1505 audit(1290443122.831:9): operation="profile_load" pid=873 name="/usr/bin/evince"
[ 13.886036] type=1505 audit(1290443122.831:10): operation="profile_load" pid=873 name="/usr/bin/evince-previewer"
[ 13.888407] type=1505 audit(1290443122.831:11): operation="profile_load" pid=873 name="/usr/bin/evince-thumbnailer"
[ 13.986925] input: ImExPS/2 Logitech Explorer Mouse as /devices/platform/i8042/serio1/input/input4
[ 14.010280] [drm] nouveau 0000:02:00.0: allocated 1280x1024 fb: 0x49000, bo ffff88006ce8b400
[ 14.010398] fb0: nouveaufb frame buffer device
[ 14.010400] registered panic notifier
[ 14.010411] [drm] Initialized nouveau 0.0.15 20090420 for 0000:02:00.0 on minor 0
[ 14.012729] vga16fb: initializing
[ 14.012735] vga16fb: mapped to 0xffff8800000a0000
[ 14.012742] vga16fb: not registering due to another framebuffer present
[ 14.035938] [drm] nouveau 0000:02:00.0: Setting dpms mode 0 on vga encoder (output 2)
[ 14.035944] [drm] nouveau 0000:02:00.0: Output VGA-1 is running on CRTC 0 using output C
[ 14.042981] Console: switching to colour frame buffer device 160x64
[ 14.160055] intel8x0_measure_ac97_clock: measured 50455 usecs (2480 samples)
[ 14.160059] intel8x0: clocking to 46875
[ 15.191780] [drm] nouveau 0000:02:00.0: Allocating FIFO number 1
[ 15.192675] [drm] nouveau 0000:02:00.0: nouveau_channel_alloc: initialised FIFO 1
[ 15.727594] skge eth0: Link is up at 100 Mbps, full duplex, flow control both
[ 15.728061] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 26.360018] eth0: no IPv6 routers present
patrice@patrice-desktop:~$
